T TheGhostInside Reputable Apr 30, 2014 10 0 4,510 May 3, 2014 #1 i have heard that some graphic's cards are backward compatible and i have also heard that sometimes you get a little bit of bottleneck and will the radeon hd7850 work with my cpu which is a a10 6790k
Solution Tradesman1 May 3, 2014 Your APU is a socket FM2, so should be PCI-E 2 and you won't be bottlenecked, what actual mobo model?
babachicken Honorable Aug 14, 2013 1,452 0 11,660 May 3, 2014 #2 probably not, do u know whether it is pci e 1.1? then it may work, but you will suffer lots of performance loss Upvote 0 Downvote
Tradesman1 Legenda in Aeternum Jun 5, 2013 67,881 41 126,960 May 3, 2014 Solution #3 Your APU is a socket FM2, so should be PCI-E 2 and you won't be bottlenecked, what actual mobo model? Upvote 0 Downvote Solution
