My motherboard isn't allowing me to control all of my fans.
I have an MSI Gaming 970 motherboard, with an FX-8350. (Old, I know)
I have the following fan setup:
2 X 120mm CPU cooler fans (Connected to the CPU fan header)
2 X 200mm Front case fans (Connected to the 3-pin sysfan header on the motherboard)
3 X 120mm cooler fans (Daisy-chained together) connected the 4-pin sysfan header
1 X 140mm case fan, as the outtake, connected to the 3-pin sysfan header.
The BIOS has a fan-control screen, which only picks up the CPU - and 2 other "system fans". It's suggested to use MSI Command center to control the others, but that only picks up the CPU and 1 other fan - which is at 0% and can't be moved (even though all the fans are spinning)
Just wondering if anyone has any suggestions on this. Also, I've tried using Speedfan, but it only picks up 3 fans, and isn't able to change their speed in any way.
Thanks in advance for any suggestions etc...
