Question My motherboard won’t power on Aorus gaming wifi
May 2, 2019
Hi guys I have a Gigabyte Aorus Z370 gaming wifi. When I turn on the power supply, it light up the logo and cmos and everything on the board that has light light up but the fans, or anyother thing connected won’t. I don’t know what to do, I just bought the motherboard.
I tried to power it on with a screwdriver
check every cable one by one
looked for other issue like case contact
But it refuses to power on.
I have
16gb ddr4 RAM 2400MHz
i7 8700k
Amd Radeon Vega 56
3Tb HDD
Two 256gb ssd one in the M.2 the other one in the optane.
i tried removing the graphic card, the ssds the hdd but nothing worked. I still get that blink on the motherboard when I power on the psu but nothing else after that.
I need help please
What SSD are they?
So try to use one SSD first to see you can boot up the PC or not.
Here is from intel about the Intel® Optane™ Memory, if the SSD does not have the Intel® Optane™ Memory H Series module, you can't use it.
I removed everything leaving only the processor and the two power cables (24 and 8 pins) I tried and again it did the same thing. Nothing but just a blink on a vga led. Could it be a bad processor? Or something I should do with the motherboard?
