So new unit and I'm still within the return window.
To try reduce the coil whine, I did a 7 hour looping benchmark in Dirt Rally everyday for the past week and a half which some says settles the coil whine. The noise has slightly improved, but nothing to say that it worked, maybe its psuedo, but idk. I have till October 28th btw if this is something I can continue to carry on to see/hear if the noise further reduces.
I'm aware of undervolting, but I like to keep it at stock settings, and for the FPS limit, I had to turn it down all the way to 60FPS to notice an actual improvement after trying 144/120/100, but going from 170FPS to 60FPS on a 240Hz monitor is no bueno.
I can definitely say this is thankfully just a case in high FPS gaming because I tried every other GPU use case from rendering/viewport stuff in Blender, using Stable Diffusion/Photoshop and the likes with no coil whine.
As such since I game with headphones on anyways, should I brush this off or get a replacement GPU if this is an unlikely case, or even more try another dual fan RTX 4070 that's more likely to not have coil whine?
