I am sorry for using the word review...i dont have the knowldge or the skills to properly test out an LCD this are more of a personal comments made by a gamer and pretty much just an averege computer user. I bought NEC1760v (black case) the colors are beatiful, the defualt brightness will cause you to go blind, but brightness and contrast are easy to adjust, if you download the free software from NEC website. At first i was worried about ghosting, because if you start moving the mouse pointer, fast around the desktop, or scroll down the webpage fast you can see the afterimage clearly, but its not the case with games. I plaied CS, BF1942 and NFS5 and did not ntoice any ghosting problems what so ever, i guess if you look hard enough you can see someting, but you will have to look REALLY hard. Its a great LCD and it does not disappoint.
Here the question i have about this LCD and LCD's in general. The suggested resloution for optimum performance is 1280 / 1024 in this case. I personally like to have my desktop at a lower resolution becasue everything is just too small. And because i have a ( P4 1.8 , GeForce3Ti200, 256DDR ram) i can not play my favorite game, BF1942 at a 1280 / 1024 resolution in a 64 player server i have no choice but to turn it down. So prety much i keep my LCD at a lower resolution then suggested All the time. My question is, how damaging is it for an LCD monitor to be at a lower then suggested resolution all the time? Should i not do this and try to keep it at 1280 /1024 at all times? ( company made it seem so important by putting a Reslution Notice that pops up all the time, until you turn it off in the option manu) PLZ answer me if you know someting about this, its a brand new LCD and i dont want it to go out of comission to fast.
Thanx in advance.
P.S.
If you have any questions about NEC1760V, or know some tests that you would like to do to test it out, tell me about it, i would not mind finding out myself. And will post about it if you want too.
Thanx in advance.
P.S.
