My new BENQ monitor arrived but when i plug in my hdmi cable from the GPU to Monitor it says no cable connected on screen ?
jdevlin530
14
Specs : BENQ GL2450 , MSI R9 380 , G3258 , MSI PC MATE LGA1150 Z97 , 1866 MHZ RAM
The new monitor arrived and it wont out put any signal , all it says is " no cable connected " any idea whats going on ?
Locate the buttons which are on the back of your monitor at the right hand side of the bezel.
Press one of the buttons and a list will appear.
Select input (second button down from the top).
Select HDMI then press the button that coresponds to the blue tick and you should be good to go.
