Hey guys, so as you can see in the title, my new pc won't power on. Everything's plugged in, no cables are loose, and when i press the power button, it's not turning on. I even went back to the store and replaced the psu with a new one. It solved the problem for a week. And now, it won't power on again. What is the problem? Can the casing cause this?
Specs:
CPU - Intel Core i7 3770
GPU - MSI GTX 970 Gaming 4G
SSD - Samsung 850 EVO 120GB
HDD - WD Blue 1TB
PSU - Corsair VS 650
Casing - Aerocool GT-R
Motherboard - ASUS P8Z77-M Pro
RAM - G. Skill Ripjaws X 8GB
Update: I've been doing some reading and I've found out that my CMOS battery needs replacement. I've read the symptoms and I've found them recently in my pc. "New cpu detected", wrong time, etc. Will replacing the CMOS battery actually make my pc power on again?
Specs:
HDD - WD Blue 1TB
