Hi, I've been doing a lot of research here at tomshardware, and it seems like the best place online to come ask this question as i've seen others ask about similar builds and receive positive feedback. I'm attempting my first build, and before I buy all this stuff and realize I'm a moron, I figured I'd ask the internets best for a critique. I want this computer to be able to play most new games, and specifically oculus rift games, therefor i need a decent framerate. I should also note that this is an extreme budget build! I am trying to build the entire system for under $400 leaving me $100 for an OS to make a $500 gaming system. After many hours of research and price comparisons, this is what I came up with:
1. First of all, I am going to build a custom case. It has a budget of it's own, we will just not go there right now, unless you have some crucial advice for case building (Im aware that this is stupid to do for a budget build, but building a case is just something I want to do for fun)
2. MoBo - GIGABYTE GA-970A-UD3P AM3+ AMD 970
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128651
3. CPU - http://www.amazon.com/gp/product/B009O7YU3S/ref=ox_sc_act_title_2?ie=UTF8&psc=1&smid=A3MDUFUQOQTCYS
4. PSU - http://www.newegg.com/Product/Product.aspx?Item=N82E16817170018
5. RAM - G.SKILL Ripjaws X Series 4GB 240-Pin DDR3
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231720
6. HDD - http://www.newegg.com/Product/Product.aspx?Item=N82E16822236070
7. GPU - PowerColor Go! Green AX5450 1GB
http://www.newegg.com/Product/Product.aspx?Item=N82E16814131338
My goal here was not only to build a system for under $500 but to leave plenty of room for expansion. My questions are simple.
-Will this build work? Is everything compatible? I know enough to know that I don't know enough to know the answer to this question.
-Will this build, as is, play all the newer video-games (ex. Wasteland 2, Elderscrolls online)?
-Are there any components in here that can be swapped with lower priced equivalents (without sacrificing future upgrade capabilities?, for ex. I want 2 PCI express slots even though i will only be using one at first.)
Also, if you have any suggestions as to the best video tutorial for putting this together I would appreciate it! Thanks in advance!
