My nextbook flexx 10 will not connect to my wifi
1.) restart your modem and wifi on your pc
2.) make sure all your drivers are up to date
you can use an app(eg: driver booster 3 which is free) to check if they are
3.) you can disable the device and re-enable
4.) You can also renew you IP address
1. Open windows command prompt Start\ Run\cmd\ok
2. To release your Ip address ipconfig /release
Enter
3. To renew your IP address ipconfig /renew
Enter
Enter
Enter
