G
Guest
Guest
Ok ill lay it all out for you guys. I recently swapped Cases from a Midsize ATX case to a FULL Tower ATX Server case. My CPU was running at a semi cool 80Degrees Fahrenheit before i swapped to my Tower case. The ONLY thing that changed internally was i upgraded from a 300W Power supply to a 400Watt Power supply. Now since i have changed cases and upgraded my power supply my CPU is RUNNING REALLY HOT IM TALKING 120Degrees Fahrenheit all the time with nothing running at all. It gets very very bad when i try and play ANY graphics intensive PC game like Operation Flashpoint, my Processor heats up and autoshuts down a 200 DEGREES FAHRENHITE. Now I have tried everything under the sun to figure out this problem that has plagued me for 2 days now. I have a 40 CFM Fan with a HUGE heatsink on the P3 FCPGA itself in perfect working condition. I have 3 Other fans inside the case as well all push massive airflow across the MOBO and Processor. And the Case Sides and top are both off. I used silver paste to correct the Temp but that only lowewred it about 5 to 10 Degrees. I have swapped Fans that didnt help at all only made it worse. I am using 2 Programs to monitor the Heat from the Chip and Mobo CPUCOOL and ASUS MBM. Both give off the same temp all the time. All other temps and Voltages run PERFECTLY in there perfect operation modes ONLY the CPU temp is the one giving me the grief. Now this is the million dollar question why is it that as soon as i swap cases both made of the same material Aluminum has my processor become so unsteady. Even at full load in my other case my CPU temp never ran over 90 Degrees Fahrenheit im talking massive amounts of windows Programs games etc etc. Now i cant play any games i cant benchmark my PC cause it hangs from the overload of the CPU Temp. I am at a loss here people any and ALL responses are greatly appreciated.
PC Specs
Windows 2000 SP2
ASUS P3V4X Mobo with newest Bios #105
890 Megs of Kingston PC133 Ram "NOT OVERCLOCKED"
Pentium 3 1000Mghz FCGPA with 133 FSB "NOT OVERCLOCKED"
Radeon 64 meg DDR with ViVo "NOT OVERCLOCKED"
Dual Maxtor 40gig 7200 RPM Drives
Soundblaster Live+Mp3+5.1
3Com 10/100 Nic Card
400 Watt Power Supply
PC Specs
Windows 2000 SP2
