My PC Build....Help!
orhun1999
7
I've picked all the parts of my build, here is the link: http://pcpartpicker.com/user/orhun1999/saved/1Vf8
I got the opinion and help of several people and they helped me make the final build. I was just wondering before I order the parts if I'm missing anything (other than the OS) and if I can improve and anything or do it for cheaper. My budget is around $700.
Thanks!
The only thought I would have is the gfx card. You may want to upgrade a notch or two. The GTX 650 is OK up to 1920x1080, but most modern graphically intense games will require you to lower settings to get smooth game play. I'd go at least a GTX 650ti or a HD 7790. Or better.
And think about going to the Haswell. The 1155 socket is a dead end now that Intel released the 1150 socket. No new chips will be made for the 1155 socket.
But as a total package, there's nothing wrong with those parts.
