Well, my pc randomly crashes (sometimes after 2 hours of gameplay, sometimes after 5 days etc.) with buzzing sound in headphones/speakers and my screen just turn into a solid color (gray, yellow, pink, cyan, black, brown etc.)
My spec.
CPU: Intel I5 2500 3,3GHz
RAM: 8GB DDR3 1333Mhz
GPU: AMD RX 560 4GB
PSU: Corsair CX 500W
Also, I just want to say that, this (I'll call it a system failure) started happening when I bought new ram,psu and gpu. And now the funny thing is that I changed everything in my PC except this new GPU and MB. I mean I'm like 90% sure it's gpu but, I don't know if that is a normal but even I changed my CPU, it's usage for example every single time I start Task Manager it just jump to 100% and then drop to 5-6, also when I'm moving my cursor left right (for example) it also go up to 50-60 and then drop. So, as I said I'm like 90% sure it's GPU but can it be a motherboard maybe or even something else. I also connected my monitor to integrated gpu and cpu was acting same. Idn anymore, I might install some old gpu and try to see if it gonna crash.
I would like to hear you opinions.
I FORGOT TO SAY THAT WHEN I TURN ON MY PC AFTER THE CRASH I GET THIS NOTIFICATION FROM AMD:
Default Radeon WattMan settings have been restored due to unexpected system failure
My spec.
GPU: AMD RX 560 4GB
