Hi,
I am facing a very strange problem. I just got a new motherboard and bellow is what happening:
If I plug my monitor to motherboard, my pc will not start, cpu fan keep spinning, no "bip ...", hdd led turned on for some seconds and off. The monitor does not display anything
But if I remove the monitor cable from motherboard and press the power button, then It works. I can plug monitor back to motherboard after that and everything just work fine
My new motherboard is Foxconn h61mxl-k, I don't have extra graphic card
Is there anyone faced this issue before? Can you please share what I can do to fix this problem?
Thank you so much for your help
