Question my pc does not turn on and it has this red light
Oct 20, 2019
i plugged in everything in my computer and then nothing worked but a red light appeared next to the 24 pin power connector on my msi b150a gaming pro i could not find what this led meant, as it was not in the manual or on the internet
i have tried to jump my power supply to see if that was the problem and the power supply worked perfectly fine
so what is the problem here ? the power supply came from a japan but i am using a converter.
edit: this is a new build
Ok so I found the led in your manual. There are three little led lights. Which one is lit top, bottom or middle one?
it is none of them it is next to the power supply connector, the cpu, dRam and vga leds are not on. the led i am refrencing is to the left of the power supply connector it has no text on it
