My PC gets extremely loud and hot
Gandalf_the_Grey
32
My PC gets rets really hot and loud when playing demanding games. I recently took my most demanding game and monitored the temperature of everything. I felt that it was very hot near the video card and it actually warmed up my hand. I will post a picture of the temperature of everything during the time I was running my game (Kingdom Comes: Deliverance on low settings).
The only moving parts of a PC are the fans and HDDs. More than likely it's a fan getting loud when you're gaming. You may want to check your fans and maybe turn them down some if that's the cause. Does it only get loud during gaming?
Temps are fine though at idle as well.
Thanks a lot for your help, and do you know how I can reduce the RPM? Also, do you know what RPM would be best suitable so I don't set it too low? Thank you so much I feel a lot more secure and happy!
