[SOLVED] My PC has two plugs for the power supply, would all of my components still get power if i just plug one higher watt psu into one
Basinho0211
39
I have a G20AJ, and it uses two power adaptors, one 180w, and another 230w. It is a desktop but is powered like a laptop. I want to get a 450w PSU but I'm only experienced with these laptop chargers. Does a normal PSU use one laptop-style plug or is it completely different?
Does the following link show the User Manual for your G20AJ
https://dlcdnets.asus.com/pub/ASUS/Desktop/a/Manual/XX09_G20AJ_E9351_V1.pdf
And the power connectivity that you are posting about is shown on physically numbered Pages 15-17. Blue identifiers 12 & 13, Page 17.
Normal PC's only have one PSU powered via one power cable from a wall outlet.
Your G20AJ is designed to have/ to work with two "PSU's" (Specs are different.)
My answer is that a single 430 Watt PSU is not viable.
Trying to switch to a single PSU (no matter how modified) is likely to damage your computer.
Reactions: jonnyguru
So should I just replace them with the standard G20 PSU? I found the 180w and 230w for the PC.
180w: https://www.googleadservices.com/pa...wjtwvOogqrpAhWVaM0KHZrfCEkQwg96BAgMEAo&adurl=
230w: https://www.googleadservices.com/pa...wjtwvOogqrpAhWVaM0KHZrfCEkQwg96BAgMEC4&adurl=
