W Will_26 Commendable May 10, 2016 10 0 1,520 May 10, 2016 #1 When I use my Sennheiser Hd 518's on my smartphone, they get reallllly loud. On my PC, they're realllllly quiet. I also tried this with earbuds and same thing. Help to get them louder?
Solution W W Will_26 Jun 4, 2016 NVM, i found the solution. i didnt install the audio drivers for my mobo. woops.
K Kathy_14 Commendable Apr 6, 2016 5 0 1,520 May 10, 2016 #2 What are you using? Windows 7, 8, 8.1 or 10? Do you know about the volume mixer? Also, have you made the headphones jack the default audio source? Upvote 0 Downvote
D dandu3 Commendable May 11, 2016 3 0 1,510 May 11, 2016 #3 http://www.amazon.com/FiiO-E10K-Headphone-Amplifier-Black/dp/B00LP3AMC2/ref=pd_bxgy_23_3?ie=UTF8&refRID=172TTN9RV7K02KY0M03Y This is what you're looking for. Upvote 0 Downvote
W Will_26 Commendable May 10, 2016 10 0 1,520 Jun 4, 2016 Solution #4 NVM, i found the solution. i didnt install the audio drivers for my mobo. woops. Upvote 1 Downvote Solution
