Question My PC is having a stuttering problem.
Oct 13, 2019
That could cause such problem too, it takes some resources away from system. It could be writing to page/swap file diue to lack of free memory.
But sometimes it does that and I'm not even running anything. Is there a way I can make it go down for when I'm not even running anything?
Oct 13, 2019
Try to turn off everything you don't need from startup, how much RAM do you have installed and how much of that is free at idle ?
I have 16 GB and it might usually use around 4gb. I have everything turned off at startup. And I just did some test, its not because my cpu or disk are at 100%, it was still stuttering and the task manager numbers were low.
Latest posts
