My pc loses the connection with the monitor and It crashes.
Czap-ka
Commendable
Feb 1, 2017
7
While playing games my pc loses connection with my monitor (it says no connection)
It seems that my computer crashes too.
Specs:
-I5 6500
-MSI B150M MOBO
-HYPERX FURY DDR4 memory (8gb)
-XFX RADEON RX 480 RS (4GB)
-SILENTIUM PC VERO L1 600W PSU (SPC132)
Drivers:
-Radeon Crimson Relive 16.12.2
The problem could be that you need to flash/update your BIOS.
Another person with a similar experience solved his issue by doing this.
Try playing windowed. If problem goes away, it may be something with display settings. If not, most likely GPU. Also you can try connecting monitor via different port on GPU or different cable. Also did you rechecked power plugs connected to GPU?
