Question My PC makes a wierd crackling sound when gaming.
Xenokal
37
Hello. My PC seems to make a weird static like crackling sound when gaming. This seems to only happen during the summer months, as it never does it during the rest of the year. I thought it may be the GPU so I applied fresh thermal paste. GPU doesn't go above 82c . When the PC is idle, the sound stops completely. I thought it could have been the PSU so I swapped it out with a newer PSU, the sound persisted. I listened around a bit and the sound seems to be coming from the rear IO panel. I was unsure entirely so I decided to ask if anyone else may have had the same issues or similar.
System Specs:
RAM: 32GB DDR4 3200mhz
CPU: Ryzen 7 5800x
GPU: GTX 1080 (other GPU keeled over so I am using old faithful)
MOBO: B550M Aorus Pro P
SSD1 Samsung Pro Evo 1GB
SSD2 Samsung Pro Evo Plus 2GB
System Specs:
CPU: Ryzen 7 5800x
It's difficult to diagnose without actually hearing the sound. Is it possible for you to upload an audio file so we can listen to the actual sound?
