My PC ready for 4K Monitor?
jimlau
200
Here are the specs of my PC. Is it ready to display 4K? Not for gaming, but action cams like GoPro.
GPU - MSI GeForce GTX 1050
Board - Z170A M3 Gaming
CPU - i7 6700K
RAM - G.SKILL TridentZ Series 16GB (2 x 8GB) 288-Pin DDR4 SDRAM
OS - Windows 10 Pro
Yes it can.
The GTX1050 specs say 7680x4320@60Hz is supported.
https://www.nvidia.com/en-us/geforce/products/10series/geforce-gtx-1050/
I am using a GTX750ti to run a 4k monitor and it does just fine.
You will need, I think a 4k monitor connected via displayport. HDMI may not do 4k@60hz.
It is. You really wouldn't be set with just the integrated GPU that the 6700K has.
Why?
DisplayPort (Version 1.4) / HDMI (Version 2.0) / DL-DVI-D
It has 3 video out ports. HDMI 2.0b, DisplayPort 1.4 and Dual-Link DVI.
Max Digital: 7680x4320
And finally Max Monitors Supported: 3
https://www.msi.com/Graphics-card/GeForce-GTX-1050-2G-OC/Specification
jimlau
200
Thanks. You mean use the DVI port?
jimlau
200
So what's the best output connection?
The display port and the HDMI 2.0b.. Which monitors are being used?
jimlau
200
Currently I am using an HDMI connector to my HD TV. Have not gotten a 4K display monitor yet. Any suggestions on what to look for in a 4K monitor? Looking for less expensive.
I would just make sure it's a true 4K monitor and it has your necessary display port and HDMI connections. Remember the version numbers on the card. HDMI 2.0 to a 4K monitor with a HDMI 1.4 connection isn't what you want. I am not well versed enough to offer a proper solution. You might want to start a new thread or Geofelt may have something to offer.
Exact top budget?
jimlau
200
was hoping under $300. Which connector's better, HDMI 2 or DVI?
HDMI 2.0
jimlau
200
It doesn't spell out the HDMI 2.0. Should I assume it has that version?
:D No. Talk to the retailer. Not even Dell is specific with the specs .
2 HDMI/MHL connector
1 DP connector and 1 mDP connector
2 USB 3.0 downstream connector
1 USB 3.0 upstream connector and 1Audio line-out port
If you peruse the questions you will see
Question: what are the differences between the S2817Qr and the S2817Q? and are the hdmi 2.0?
Answer: The S2817Qr is simply the model for the version available from our retail partners. The S2817Qr and S2817Q are identical products from a spec, design, and performance basis. The HDMI ports available on this are version 2.0
By Eric L @Dell on March 20, 2017
https://www.amazon.com/ask/questions/Tx3N9253M08JLV4/ref=ask_dp_lsw_al_hza?asin=B01MQ1COOF
If you had a better GFX card I would have suggested a 1440p 100Hz or better(144Hz) monitor or TV. Fast paced scenes benefit from higher refresh rates due to more frames being available. https://www.pcmag.com/article2/0,2817,2379206,00.asp is one of a LOT of articles explaining refresh rates. Because this seems to be specifically aimed at GoPro action scenes the higher refresh rate will present a smoother experience on the monitor.
