My PC say "no signal" when i using Graphic card, but when i remove my graphic card it works
Reysch
Commendable
Oct 29, 2016
Hello guys,
recently I brought a new build for my pc (fyi all parts was new). when i finished all my parts installation and ready to install OS for my pc, when i turn on my pc, it says no signal, but when i read some FAQ's i try to remove yg graphic cards, and its works perfectly and i can install my OS (my os win10) but i still cant find the exact problem why my pc cant get any signal when i use my graphic cards, anyone know where the problem is and what should i do?
my rig is
-mobo : msi B150M pro-vh
-psu : corsair vs450
-graphic card : galax geforce gtx1060
-ram : gskill ripjaws ddr4 16gb
-cpu : i5-6400
Make sure you have your HDMI cable going into the card
Make sure it is getting power from the motherboard
Make sure it is securely in the slot
If it still doesn't work then go for a rma.
