I have a cooler master 800w gold 80plus but I know the psu is not the issue because I asked my dad to use his Corsair 1000w psu and the issue still occuredWhich power supply unit/PSU are you having ? List the exact model and brand.
Then most probably the GPU, video card is faulty then ? I would also make sure to check the CPU thermal paste, heatsink/fan etc.. Also, try to reseat the RAM on the slot once again. If need be, use 1 stick of RAM module.
Which Motherboard do you actually have ? Does it have support for onboard graphics, igpu ?
the problem still occuredIf you have multiple GPU pcie cables and pulled one from a bag, make sure it's the one designed for your power supply. Even though the molex connector might fit perfect the pin out can be different from one brand to the next
I think it is the gpu since a couple of days ago I did smell smoke because of that I took a break its probably my gpuThen most probably the GPU, video card is faulty then ? I would also make sure to check the CPU thermal paste, heatsink/fan etc.. Also, try to reseat the RAM on the slot once again. If need be, use 1 stick of RAM module.
