Question My pc starts for a second then stop and then starts normally.. help??
Feb 27, 2020
Hello everyone i really need help
Sorry about my bad english
So the problem is that when i press the turn on button the pc starts and the fans spin for a second then stop for a second then starts again normally..and it takes me to the bios screen.When i exit the bios screen the computer works normally.
Should i be concerned?
I didn't change or replace any part of my pc and its a new problem that came out of no where.
Any ideas?
And thank you so much for helping.^_^
Feb 27, 2020
Which motherboard is it?
Is the date and time set correctly?
Update the BIOS within the BIOS (not windows)
check the boot order in BIOS
My motherboard is asus strix Z370E
My boot menu is set to my ssd
The date is correct but time is not ..it changed
I'll try to update the bios
Thank you sir i will tell you what happens with me...
Much thanks
Feb 27, 2020
replace the CMOS battery if the update didn´t help
The update didn't work
Still the same problem
I press the turn on button once..the pc is On for a second...then off for a second then ...then works normally
It's not giving the CMOS failure window i don't think its the problem.
