Question My pc won’t boot after changing to water cooling
May 21, 2019
4
My pc won’t boot after changing to water cooling + replacing ram, no power at all no lights, fans not spinning at all. I don’t know why pretty sure everything is installed fine, everything is working fine before i change it to water cooling and all, any fix or solutions? Pc is 3 months old
Ryzen 3 2200g
Gigabyte a320
Corsair vengeance pro 8x2 3000mhz
80+ 500w psu
Lutfij
You should ideally list your specs like so:
CPU:
Motherboard:
Ram:
SSD/HDD:
GPU:
PSU:
Chassis:
OS:
You should also add the make and model of the PSU as opposed to just it's wattage. The other matter is the make and model of your watercooler, if it's an AIO or a custom kit. Often times, a backplate that has been tighten too much can cause the system to not boot.
May 21, 2019
4
Check all cables are plugged in correctly
remove the watercooler and put the old one back and see if it boots.
strip it down to bare minimum, CPU and 1 Ram stick
Hi, i tried powering my psu alone and it worked, problem is ram stick is not lighting or working
May 21, 2019
4
CPU:
Motherboard:
Ram:
SSD/HDD:
GPU:
PSU:
Chassis:
OS:
Hi, computer turned on power, but my ram stick doesn’t light up is there a chance that the Mobo has been broken?
