H Had3s Mar 10, 2019 1 0 10 Mar 10, 2019 #1 I took my GPU out for cleaning then when I put it back in my pc won't connect to my monitor. Iv trives to use a different cable and remove the GPU but nothing worked
Phillip Corcoran Titan Moderator Sep 7, 2013 26,104 912 120,140 Mar 10, 2019 #2 You may have killed the GPU by handling it incorrectly and/or the cleaning method you used (eg brushing it is definitely a killer). Upvote 0 Downvote
