Basically i unplug and replace my new SSD power connector while psu still on, pc wont open anymore. Just wondering what is the problem and what should i replace? mobo or psu
May I Ask What You Mean When You Said "Now my PC Won't Power On"..Basically i unplug and replace my new SSD power connector while psu still on. Just wondering what is the problem and what should i replace? mobo or psu
Does it Mean that Your Computer wont POST,Stuck in Boot Loop,Won't Boot Into Windows etc?
Keep us Updated
have you tried to flash your bios already? i know it's kinda dumb but i guess you dont have anything to test your psu and motherboard at home.Completely dead PC, fans cpu fan not spinning, not posting not sure about the PSU though. I wanna know between the PSU or mobo is at fault.
i would try to swap parts from your pc to your old working pc for example. try to run your pc with another power supply. i'm totally not sure but it might be a short circuit.Yeah it's not possible so i'm just going for the fastest solution here buying new part, but i want to know what part to replace. Can i test my part somehow its there a way?
actually your psu won't let electricity damage your components. but it depends on it's specs. idk how it called protections or smth else. i'd really try to swap psu, mb borrow from a friend.Short is my conclusion about it. It would suck if it indeed shorting is the cause would all the components would be damage too? hopefully not.
