[SOLVED] My pc wont power on after switching PSU
Did it turn on by itself then turn off when plugged in? If that’s the case I’d try leaving everything plugged in and try jumping the two pins on the motherboard that normally turn it on, if it still doesn’t turn on I would think either there’s a short somewhere (like a dead graphics card or hard drive) or the psu has an issue.
It's a brand new psu. I think I did something to the front panel connectors as the psu started when I first put it in but only put the 24 pin in. But it's now not starting
That’s why I said try jumping the two power pins on the motherboard with a screw driver if you are confident enough because if the power button is faulty then the pc won’t turn on without it.
