My PC won't start after i cleaning Like totally dead
Oct 14, 2018
4
Hi everyone i need help.
I just cleaning up my PC from dust with brush. Before it, i put out all cable from motherboard, put the gpu, put the cpu fan. The i clean it up.
After that, i put in back again the cable, gpu etc. When i press the power button, nothing happen with my pc. I see the light on the motherboard is on. But my pc won't turn on at all
Yes i put the cable back again just like before i clean up. I even see the user manual from the motherboard
I am going to refer you to our general troubleshooting thread:
http://www.tomshardware.com/forum/261145-31-perform-steps-posting-post-boot-video-problems
Work through the list.
WORK!, not just read!
If you still have issues, come back here with the results of working EACH step in the list, and we will try to help. Since we can neither see nor touch your PC, the results of each step in the list allows us to elininate possible problems and common errors, and give you a reasoned diagnosis. Help us to help you!
Step 1: I've read the user manual from my motherboard. I'm using Asus H81M-E. And follow all instructions in the Manual.
step 2: my motherboard have 4pin, so i just plugging in 4 pin into the motherboard.
Step 3: yes all standoffs installed
Step 4: my GPU is seated correctly
Step 5: my GPU Rodeon RX560 doesn't have PCI-e power
Step 6: I have 16Gb(2x8GB) Ram. I've tried just using 1 card. The problem is. Still it won't turn on. And there's no "beep" sound from ram.
Step 7: yes all memory inserted correctly
Step 8: I've read the manual many times
Step 9: there's no plastic guard on the cpu socket. Because before i cleaning up my pc. I'm still able to turn on and playing games
Step 10: when i cleaning up my pc. I'm not putting the cpu from the motherboard. So it's still there
Step 11: there's a bend pin on the USB connector and jumper. But i think this doesn't matter because before i cleaning my pc it's work fine.
Step 12: I'm still using cpu fan from Intel. I'm planning to buy an aftermarket cpu fan in the future
Step 13: yes the cpu fan was installed correctly
Step 14: there's no another material on the thermalpaste
Step 15: all screw installed correctly and the cable from psu was going through behind the motherboard
Step 16: yes. if not I can die electrocuted
Step 17: I don't have system speaker
Step 18: i think this is the problem. I have a conclusion because when i plug in the power cable into the PSU, the small light on the motherboard is turn on, but when i push the power button from Front Panel of my pc case. Nothing happen. I've read the user manual many time to make sure i Install the front panel cable into the mother board. I've followed it from the manual but still nothing happen to my pc
Step 19: I've turn on the psu and the small light on the motherboard is on
Step 20: yesterday I've downloaded the newest version of windows and my gpu driver.
Step 21: yes i tried resetting cmos following from the manual. I even tried to jumper and put the battery from the instructions in the manual. But still nothing
Step 22: how i integrate it if my pc won't turn on?
Step 23: I'm sure all cables and components are installed correctly and tight to the socket
You used a brush to clean around the motherboard & components?
Very bad practice indeed. You're supposed to use an air-blower so nothing actually gets touched by anything that might cause ESD (Electro-Static Discharge) which can kill some computer components.
Hopefully that hasn't happened and it's just a case of something you haven't reconnected properly - - so double-check everything.
Yes I'm using soft brush that usually use for painting on paper.
I just solved the problem got help from my friend. Dunno what it's mean but when I'm plugging CHA_Fan the PC won't turn on, but if i put the CHA_Fan my pc is running now.
RE: Step 6 and 17; there will be no beeps of any kind without the speaker.
