My Pc Won't Turn On Please Help!!
Mar 9, 2018
21
Sir, Recently I Buy A PC Having
RAM:1*8Gb Stick
Processor: Intel I-3 7100 LGA 1151
Motherboard:MSI H110M PRO-VH PLUS
Graphic Card:Asus GTX 1050Ti
I Buy This PC Just Two Months Ago But In The Morning, I Get shocked When My PC Won't Turn on.I Google it Then I think there is a Problem in my PSU, so I Replace It But After Replacing Power supply Nothing Happen, My PC won't Turn On And All Cable Seems Tight and fine. plz Help Me!
May be My CMOS Battery get damage Because Due to exam I Don't turn on for 1 months.
Same Output 450W And Thanks For your Reply Sir Plz Help me
Ok. bro Thanks for Response. I connected 24pin Correctly And also A 4 pin Connector to the Mobo and My graphic card Doesn't require Any Power Input.
Vikin I understand That You will Have To complete To Complete Your sleep But After completing Sleep Plz help Me I Will be Waiting fro your Reply
That's My Mobo Image
