Question My PC's side glass panel is hot
Apr 25, 2022
4
Hello, I recently upgraded a few components in my PC. I noticed that my glass panel is getting warm whenever I touch it while a game is running. So, I want to ask if this is safe for the case or the components inside it? Both the GPU and CPU's temps while gaming are around 50-60 C. My fans layouts are 2 intakes in the front, 2 exhaust on top and 1 exhaust in the back.
Here is a picture of the inside: I think the airflow is fine but if you notice something wrong, please let me know
View: https://imgur.com/a/lWTpCjk
GPU too close to side panel and as it's glass or plastic it's an insulator.
Reactions: JustWonderingLoudly
Is it safe? I plan to get a new case down the line, but that'll take a while (at least sometime in 2023)
Do you think it'll last til then?
The problem with having a glass panel too close to the video card is that video cards mostly blow air sideways. So they need some breathing room to let that air flow out. However, this is only really a problem if your video card is more than 5-6" wide. But as long as the temperatures of the video card itself is fine (most things under 85-90C), then it's nothing to worry about.
The only hazard I'm seeing is if the glass becomes too hot to touch. It's a potential burn hazard on top of if you throw something ice cold on it, it could shatter the glass.
I'm not assuming custom fan curves. The stock fan curve typically adjusts fan speeds to maintain 70-75C and turns off the fans around 55-60C.
well this is what my GPU's thermals generally looks like when I'm gaming:
View: https://imgur.com/fx246go
Could be because I'm mainly playing in 1080p but yea. 50-60C is accurate for my case at least. Pushing it to 1440p via DSR does bring it up to 63 C though
Game in image is Ghostwire Tokyo
Also just in case, if you do notice some wrong or abnormal, please let me know
