S Stephin Commendable Jul 10, 2016 1 0 1,510 Jul 10, 2016 #1 Pen Drive is showing in the Disk Management screen, but not able to rename or format.
Solution Phillip Corcoran Jul 10, 2016 You should be able to format or rename a pen drive from within Windows Explorer by right-click on pen drive icon. If it doesn't work, the pen drive may be faulty (a very common problem) so try a different pen drive as a test.
Phillip Corcoran Titan Moderator Sep 7, 2013 25,971 852 120,140 Jul 10, 2016 Solution #2 You should be able to format or rename a pen drive from within Windows Explorer by right-click on pen drive icon. If it doesn't work, the pen drive may be faulty (a very common problem) so try a different pen drive as a test. Upvote 0 Downvote Solution
