My g4600 cpu is inside my motherboard but device manager, task manager, and my motherboard bios recognizes it as a g4560 and i dont know how to get it to be recognized as a g4600 and run at its original clocked speed and power.
Unfortunately the g4600 has been supported since day 1 -- https://www.asrock.com/mb/Intel/B250M-HDV/index.asp#CPUhttps://www.asrock.com/mb/Intel/B250M-HDV/index.asp
Bios:
Brand: American Megatrends inc.
Version: P2.20
Date: 05/11/2017
What motherboard and BIOS version? Might need to update the BIOS.My g4600 cpu is inside my motherboard but device manager, task manager, and my motherboard bios recognizes it as a g4560 and i dont know how to get it to be recognized as a g4600 and run at its original clocked speed and power.
where do i go to check? cause it happened ever since i got the pc and i never even upgradedWhat motherboard and BIOS version? Might need to update the BIOS.
Download and run CPU-Z -- https://www.cpuid.com/softwares/cpu-z.html It will list the model of your motherboard and the BIOS version.where do i go to check? cause it happened ever since i got the pc and i never even upgraded
Is it possible you don't have a g4600 ? CPU-Z is pretty good at showing the truth. If it says g4560 you might really HAVE a g4560.i did it, and it displays as a g4560 even tho i have a g4600
Give us the motherboard brand, model and the BIOS version you have. We can see if that BIOS supports your g4600 CPU.i dont think so i checked my cart and it says i got a 4600 unless i was scammed then i would be sorry for bothering you kind people
Bios:
Version: P2.20
Date: 05/11/2017
