Solution A A Alabalcho May 9, 2018 What is "Pepsi MP3"? If it is some type of MP3 player - check your charging cable, and charging adapter. Providing that there's no info about such a player online, I would assume it something cheap to replace.
A Alabalcho Titan Jan 13, 2011 14,016 433 81,090 May 9, 2018 Solution #2 What is "Pepsi MP3"? If it is some type of MP3 player - check your charging cable, and charging adapter. Providing that there's no info about such a player online, I would assume it something cheap to replace. Upvote 0 Downvote Solution
bignastyid Titan Moderator Jun 19, 2011 33,689 1,700 159,590 May 9, 2018 #3 Make sure you are not using a Coke or RC charger. Upvote 1 Downvote
D Deleted member 217926 Guest May 10, 2018 #4 bignastyid : Make sure you are not using a Coke or RC charger. Mr. Pibb should be compatible though. 😉 Upvote 0 Downvote
DSzymborski Curmudgeon Pursuivant Moderator Nov 19, 2010 21,202 5,329 106,640 May 10, 2018 #5 bignastyid : Make sure you are not using a Coke or RC charger. Mr. Pibb should be compatible though. 😉 Dr. Pepper actually completed *his* graduate work. Upvote 0 Downvote
