What PC/Mobo/Ethernet card do you have?
A easy test would be to make sure its not a bad cable or somethings wrong with the router, best test would be to hook directly into the modem using a new cable.
Next step would be to uninstall and reinstall the network drivers either via windows or the better option via the product support page for you computer/mobo/networkcard manufacturer.
