Question My plan for my first PC (DDR5 machine)
Build looks fine but I wouldn't buy into Kingspec gear and wouldn't buy Noctua fans out of the gate. I would work with stock parts first, see how they are and then save money to buy more fans down the road.
What will this PC be taxed to run...? Without context this build can be a brilliant build but in reality struggle to do what you want(to an extent).
You're also advised to stylize your post with info asked of in this thread;
including your location, your budget and your preferred site for purchase, apart from what the system will be taxed with(in terms of app's/games, if it's meant to be gaming).
Reactions: LuKaWin10
Build looks fine but I wouldn't buy into Kingspec gear and wouldn't buy Noctua fans out of the gate. I would work with stock parts first, see how they ar and then save money to buy more fans down the road.
Ohh, sorry. My location is Croatia, sites where I will buy will be only Croatian (Links.hr, Instar Informatika, HGSPOT, ADM.hr, and more). Budget is around 1800 dollars. And my PC is meant to be for gaming! And I am planning to build it in Summer 2025, but until then, I will still see what will happen with new hardware. I will be checking this link you sent me as it is a good guide for beginners (like me lolz)
And for that Kingspec gear, well, you are right. I only put that in just so I have something, it is not something I would actually buy. I only plan on getting some sort of M.2 NVME SSD that has a DRAM controller. And I fully agree for the Noctua fans, it is advised to first see how the PC performs then in the long run to see if I need any more fans!
That Gigabyte Eagle comes with the old school 1G LAN. Look for a board with a 2.5G LAN.
PCPartPicker Part List
CPU: AMD Ryzen 7 7700X 4.5 GHz 8-Core Processor ($278.99 @ Amazon)
CPU Cooler: *ID-COOLING FROZN A620 PRO SE 58 CFM CPU Cooler ($29.99 @ Amazon)
Motherboard: *MSI B650 GAMING PLUS WIFI ATX AM5 Motherboard ($149.99 @ MSI)
Memory: *TEAMGROUP T-Create Expert 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory ($90.99 @ Amazon)
Storage: *MSI SPATIUM M482 Eco-Pack 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive ($99.99 @ MSI)
Video Card: Gigabyte GAMING OC Radeon RX 7800 XT 16 GB Video Card ($469.99 @ Newegg)
Case: *Montech AIR 903 BASE ATX Mid Tower Case ($65.00 @ B&H)
Power Supply: *be quiet! Pure Power 12 M 750 W 80+ Gold Certified Fully Modular ATX Power Supply ($82.90 @ Amazon)
Monitor: *MSI G244F E2 23.8" 1920 x 1080 180 Hz Monitor ($109.99 @ Amazon)
Total: $1377.83
*Lowest price parts chosen from parametric criteria
Generated by PCPartPicker 2024-10-17 08:38 EDT-0400
That Gigabyte Eagle comes with the old school 1GB LAN. Look for a board with a 2.5GB LAN.
Total: $1377.83
Hey thanks, you saved me lots of money 😎. I like the parts, impressive! Ty!
Reactions: Why_Me
