My Planned PC Build - Advice and Finalizing the System Layout
S_Lans
23
I have collected a list of parts that I would like to buy, and have done a fair bit of research regarding the compatibility and performance of the parts. However, I am still very new to PC hardware, having only ever installed new RAM and a GPU in my current PC.
Please note that I already own the graphics card I will mention, and I am going to upgrade to a 10 series Nvidia card in the far future.
I also considered buying intake fans for the case, but since the motherboard I am interested in only has 4-pin PWM fan connectors, I am struggling to find appropriate fans. The intake on this case can take two 140mm fans. Advice on this subject would be much appreciated.
This is a list of parts I have planned to buy:
If there are any incompatibilities, or if you can recommend a better part I would appreciate it greatly. Also, if there is anything else that I am missing from my 'shopping list', could you tell me so I can make sure I have everything for when I buy the parts.
Thank you,
S_Lans
It would be easier for people if put your build together in PCpartpicker, and export the bb code or permalink.
https://uk.pcpartpicker.com/list/
Just looking at that list, there are definitely some better options out there. Do not need thermal compound. Cryorig H7, or H5 universal, would be a better cooler. 120gb SSD is not very useful. The 6600k is an older gen too. Might want to consider a Ryzen 5 1600, if you want to overclock.
Thank you for the response, why would I not need thermal paste? I thought it was needed to act as a thermal conductor between the processor cover and it's cooler.
Also, thanks for recommending an alternative CPU cooler, they appear to be well reviewed. :)
I might just stick with the 6600k for now, unless a better alternative arises, since Ryzen does not seem all too appealing to me, considering the smaller selection of parts and my inexperience (I'd prefer to stick with a CPU that has a lot of documentation regarding installation and compatibility).
Finally, I will definitely consider a larger SSD, are there any 250GB (or there about) drives that you would recommend?
because the cooler you're getting already comes with it. so why waste money?
