X xdidnotdidx Aug 6, 2018 3 0 10 Jan 16, 2019 #1 My graphic card has a 8 pin hook up and my supply does not I was wondering how I know what power supply I need to buy and if I buy a different one will I still be able the power my motherboard and things
Solution K K King_V Jan 16, 2019 If your power supply has TWO of the 6-pin connectors, you can use a dual-6-pin-to-single-8-pin adapter.
Dark Lord of Tech Retired Moderator Aug 18, 2009 128,614 1,778 159,590 Jan 16, 2019 #2 Specs please then I can help. Upvote 0 Downvote
vapour Champion Aug 28, 2017 12,398 98 57,540 Jan 16, 2019 #3 can you list the model number of gpu and psu? Most likely you need a new psu. Upvote 0 Downvote
K King_V Illustrious Ambassador Nov 1, 2014 8,126 2,300 39,590 Jan 16, 2019 Solution #4 If your power supply has TWO of the 6-pin connectors, you can use a dual-6-pin-to-single-8-pin adapter. Upvote 0 Downvote Solution
