my power supply has a loose connection HELP!
You'll want to replace your power adapter if the wires are bad but the more common problem is that the power jack gets broken (which results in a loose connection). I'll suggest replacing the power adapter but, if you have that same problem afterwards, then you can be assured it is the power jack itself (repairable most of the time)
the loose end is where you put the cable into the computer,yes. but to find out the model number i have to look under my computer and i have my cable setup in a wierd way so i get power and if i move my computer ill lose it :/..
no.. it the cable that has a loose connection when i move the cable around sometimes i get power.
