Please tell me what you think of this build. I plan to purchase in 1 month. Monitor resolution 1920x1200. I plan on over clocking to 3.8-9 and need a lil help with making sure i get the proper stuff to make it happen. This will be a gaming rig.
COOLER MASTER HAF 932 and COOLER MASTER RS-700-AMBA-D3 700W ATX12V V2.3 SLI Certified CrossFire Ready 80 PLUS Certified ( might have to take it to 850)
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.208777
i7-920 and ASUS P6T LGA (please help with a better OC option if possible)
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131359
Scythe MUGEN-2 SCMG-2000 120mm Sleeve CPU Cooler
http://www.newegg.com/Product/Product.aspx?Item=N82E16835185093&Tpk=mugen%202
OCZ XMP Ready Series 6GB (3 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Low Voltage Desktop
http://www.newegg.com/Product/Product.aspx?Item=N82E16820227388
Western Digital Caviar Black WD5001AALS 500GB 7200 RPM 32MB Cache
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136320
BFG Tech BFGEGTX275896OC2E GeForce GTX 275 896MB 448-bit GDDR3 (plan on getting another also)
http://www.newegg.com/Product/Product.aspx?Item=N82E16814143199
Microsoft Windows Vista Ultimate SP1 64-bit (should i just get the basic?)
http://www.newegg.com/Product/Product.aspx?Item=N82E16832116678
ASUS VK266H Black 25.5" 2ms
http://www.newegg.com/Product/Product.aspx?Item=N82E16824236046
Grand Total: $1,729.48
Any suggestions, recomendations or thoughts would be sweet.
