so far im happy with the spec of my pc , but i plan to watercool it as its something i fancy doing , but i dont want some naff prebuilt so heres what im proposing to buy soon and build.
Swiftech Laing D5 Vario MCP655 12V DC Pump
D-Tek Fuzion V2 Universal CPU Block
XSPC Single Bay Reservoir
EHX-1020BK 3-Fan Radiator and Fans/Shroud
VID-487X2 (Radeon HD 4870 X2)
plus all the piping and ancillerys , im going 1/2 ID piping as i think that pumps more than capable ,
i plan to cut the coolance radiator kit into the top of my akasa case , this might need a few tweaks but ive printed off the template and it looks promising
ill have a full UV effect with side window. this setup should provide ample cooling imo. my order will be Pump>Rad>Cpu>Res>Gpu>Pump , hopefully running
the system through the reservior after cpu will cool it sufficently before entering the gpu.
when its underway ill take pictures , just waiting for some money im due to come through so i can get this going. gonna need to mutilate the top of my case
thankfully the akasa eclipse has a removable lid so i can put it on my workbench and cut there.
ive done alot of reading up and im happy with choices , any opinions always welcome or experience with these components.
