Having some noise issues with my Seasonic X series Gold rated PSU. It sounds like a hiss. It comes and goes randomly even when the system is idle. This psu is equipped with a 0 rpm fan feature, and it's for this particular reason that I am certain that it's not fan related. Google search lead me to coil whine, however I'm not sure that's what this is.
I am using passive cooling for cpu and gpu and the rest of the system doesn't even get hot enough to even need case fans. There is only one SSD drive being used so the system is totally silent. The psu is way overkill for what I'm using it for, so by no means placed under any real stress. It is however nearly 10 years old, but used lightly throughout it's life. I have experienced no other issues apart from the noise.
I would rather not replace if there's a simple fix. If anyone can offer some advice or tips I would be grateful.
Thanks.
Thanks.
