C Cormac Duffy Reputable May 24, 2014 1 0 4,510 May 24, 2014 #1 I have a xfx 650w psu and it only has 8 pin but in need 6 pin can someone help me.
Solution jimthenagual May 24, 2014 I'm assuming this the PCI-E for your graphics card? Most new power supplies now come with a 6+2 pin, meaning you can pull it apart into a 6 pin with 2 extras that you simply leave unplugged.
jimthenagual Splendid Apr 8, 2012 4,005 16 29,365 May 24, 2014 Solution #2 I'm assuming this the PCI-E for your graphics card? Most new power supplies now come with a 6+2 pin, meaning you can pull it apart into a 6 pin with 2 extras that you simply leave unplugged. Upvote 0 Downvote Solution
geofelt Titan Oct 9, 2006 54,295 4,145 174,240 May 24, 2014 #3 Your psu has 6+2 connectors; it is designed to leave the +2 hanging loose if you only need 6 pins. You are good. Upvote 0 Downvote
scout_03 Titan Ambassador Feb 18, 2010 30,566 321 107,640 May 24, 2014 #4 this is your psu check carefully it have the 6 pins cable http://products.xfxforce.com/en-gb/Power_Supplies/Classic_Series_650W_PSU/P1-650X-CAH9 Upvote 0 Downvote
