my Psu stopped doesnt turn on! Please help
EireSionnach
46
Hi I was getting my computer built and everything was correctly put in then my seasonic s12ii 520w 80+ bronze psu didnt power on anything or even turn on itself please help Ive tried different outlets and plugs. Is this normal?
Check the front panel connections carefully; they're tiny. You might try the paperclip test to make sure the PSU will turn on. This involves using a paperclip to short the green sense wire in the 24-pin power cable to a black ground wire; Google will have images and more information on how this is done.
My motherboard is the asrock h97m atx anniversary mounted by standoffs, gtx 960 2gb, 1tb hardrive, 2x4gb ram
