[SOLVED] My Ram doesnt work on normal speed.
dassan
65
Hello i ve just bought a pc with these specs:
AMD Ryzen 3 3100 3.9GHz cPU
Asus Prime B450M-K Mobo
G.Skill RipjawsV 8GB 3600MHz DDR4 Ram
In my system rams work on 3200 Mhz eventho its normal speed is 3600 Mhz. I cant get it to 3600 otherwise my fans etc seems to work but i get blackscreen
cant even get to Bios. I updated my mobo bios but it didnt solve the problem . Could you help me on this issue plz?
This is a common issue. There is no guaranty that your memory will run at its rated speed in your system.
Is your motherboard BIOS the most recent version available? If not, that may help.
Keep in mind that the performance difference (3200 vs. 3600), from a normal user perspective, is minimal. You might seem some difference when benchmarking, but overall not so much.
