hello thanks for answering my question. hmm there is no BIOS update in myasus application. my os version is windows 10 with OS build 19042.1415. sorry but I don't know how to resetting the ram stick. and I already remove the other ram rn. its my bad for mix and match ram.Welcome to the forums, newcomer!
Can you check and see if the laptop is pending any BIOS updates? As for your OS, what version(not edition) of Windows 10(assuming you're on Windows 10) are you working with? Have you tried reseating the ram stick that came from the factory(and remove the one you purchased)? Also, please do not mix and match sticks of ram, that's the first mistake you've performed. As a side note, please parse a picture of both sticks of ram in your laptop.
then what should I do. use 2 stick 3200mhz ram or mix it? because the maximum frequency is 2400mhz.Welcome to the forums, newcomer!
Maximum frequency supported by the Ryzen 5 3550H(assuming you're on that APU, even on the Ryzen 7 variant) is 2400MHz.
