Solution digitaldoc Jan 8, 2015 Most likely, your tv is not powering on, and will need to be replaced. Before tossing it, try a different HDMI cable, confirm the signal is ok, and that your outlet and surge strip are working ok.
digitaldoc Expert Ambassador Oct 31, 2003 5,213 0 36,960 Jan 8, 2015 Solution #2 Most likely, your tv is not powering on, and will need to be replaced. Before tossing it, try a different HDMI cable, confirm the signal is ok, and that your outlet and surge strip are working ok. Upvote 0 Downvote Solution
