My right arrow key = Alt Ctrl. What is going on?
KIll xd
20
So today whilst I was trying to use my arrow keys to game, I found out that my right arrow key was not working. I immediately uninstalled the drivers and downloaded the up to date ones. Re-booted pc and still nothing.
Faulty keyboard? I removed the key cap to check if anything was interfering but it was clean since I only had it for 3 months.
I used an online keyboard tester and it says <Alt> <Ctrl> when I press my right key.
What is going on?
Some sort of internal failure or defect, not much you can do about it other than have it replaced. Depending on how the keyboard is built, it could also be something 'falling' in.
I'll try to contact customer support in the meantime to see if they can issue a replacement .
My keyboard is Asus Claymore.Payed a crap ton and I'm starting to think I should have bought the Corsair Strafe.
