Question My SATA head cable got stuck under motherboard. Is it safe to pull it out?
May 2, 2021
As mentioned above. I am a bit curious about what may happen under the motherboard electrical bond if I pull it out because my cousin says it is not to worry about it cause the solder tin is really hard to break. Is it true?
Thank you for your help!
USAFRet
141,076
7,855
174,040
21,821
If you just pull it out and something breaks, is your cousin going to replace it?
No.
Take it apart as far as necessary to remove the cable without tugging.
