[SOLVED] My screen is wierd Help
Jan 14, 2020
9
Hello! My problem is that i installed my new gt 1030 like a month ago but when i first installed it the screen was wierd and glitchy. Then i did ddu installed it again and the new drivers it seemed like it has no problems. But now after a month the wierd glitch came back.. I don't know shpuld i do
Heres a picture of the wierd screen:
https://ibb.co/S0ZMWmn
Check the monitor cables, if possible try new ones.
What is the exact make and model of your PSU? Actually FULL system specs please
Usually that kind of thing, means faulty GPU. If you used DDU already that makes it even more probable.
I3-3220 cpu
H61m-ds2v motherboard
I don't know thr model of my psu but it's a 450w one. I can check it tomorrow.
I have an old monitor it has d-sub port and my gpu has d-sub port too so i use d-sub
I have an old hdd to 465gb
Sry for the bad english
